Discuss Wiring a y-plan system for a worcester greenstar 28he without capacitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nas
Is there a way of wiring this boiler to a y-pan system so it does not require a capacitor on the switched live. I have wired it up but the heating will not switch off. After checking everything Im assuming it's because I've not got the capacitor in the circuit.
Thanks in advance
I have never fitted a capacitor on these double check the wiring see what voltage you get on orange wire with everything off.
The problem with Y plan is that you get a potential difference between orange and neutral when the valve is off.
This is sometimes sufficient to operate some boilers when it is connected to the SL.
Doesn't happen with S plan.
Reply to Wiring a y-plan system for a worcester greenstar 28he without capacitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
