G
gobyfish
Hi everyone, I'm Mike from Bristol.
Hoping someone on here will be able to help us
I've had to replace the boiler feed on our system, and hopefully someone can advise me if I have wired it back up correctly.
http://i736.photobucket.com/albums/xx1/mianikamoo/General/Boiler/diagram.png
http://i736.photobucket.com/albums/xx1/mianikamoo/General/Boiler/Controllerwiring2.png
http://i736.photobucket.com/albums/xx1/mianikamoo/General/Boiler/controllerwiring.png
When the fused supply is switched on, the pump is constantly running (which I don't believe it should be) and the programmer has no effect on the boiler operation.
To cut a long story short, the programmar has been replaced, there is no click from room stat, there may be a problem with 3 way valve(defaults to W position) but I can't say for sure until I know the programmer backplate is wired correctly.
If it helps the boiler is an Ideal Classic, the programmer LP522 mk 4(replaced old LP522 which is knackered) Drayton 3 Way, Drayton room and tank stat.
I an old friend of SWMBO's who is a plumber is tryign to help and I appreciate not being physically in front of the system makes life a lot harder, but any help would be greatly appreciated.
We have been without heating for over a year because we simply cannot afford to call someone in and when we did he refused to look at it because I have replaced the boiler feed myself.
Thanks in advance
gobyfish
Thanks in advance
gobyfish
