Discuss Worcester 28i Junior prv blowing after replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Ranpan
Hi the boiler had been losing pressure for some time so we kept topping it up. We diagnosed that the prv had gone because it had been blowing and the expansion vessel had gone because it was letting water out instead of air. We replaced the prv and attached an external expansion vessel. We refilled the system, bled the radiators, got the pressure right on the boiler and everything was working fine with the heating on for about 4 hours. Then we turned the heating off and we lost pressure, over night the pressure went from just over 1bar to 0 and the prv had been blowing again. We're confused as to why it's still blowing, if anyone can shed some light on this it would be great, thanks :)
You need a competent gsr to look at it rather than willy nilly replacing parts.
Reply to Worcester 28i Junior prv blowing after replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve...
Got a Worcester green star 28i junior that was blowing off, replaced PRV now it won’t pressurise at all, just fills for a few minutes then blows...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
