Discuss Worcester 30cdi loud rumble after hot tap turned off in the USA area at PlumbersForums.net
Hi. Our Worcester 30cdi makes a very loud rumbling noise after the hot tap is turned off. It seems to be worse if the hot tap is only run for a short time. The noise is getting worse since this video was done. Any advice gratefully received.
when was the boiler last serviced?
Reply to Worcester 30cdi loud rumble after hot tap turned off in the USA area at PlumbersForums.net
