Discuss Worcester Bosch Greenstar 30 CDi - Pressure loss in the Central Heating Forum area at PlumbersForums.net
Hi all,
Recently moved into a new house and noticed the Greenstar boiler has low pressure on the dial.
Quick Google suggests using a key, valves, or fill loop to increase the pressure. Only problem being is I don't have either of those things.
Any help would be appreciated.
Cheers.
If you look underneath you will need to remove the white plastic cover if you can see the valves this is already removed
Right two pipes there should be a white square connected to the two brass valves don’t touch this yet report back if you see this or post a picture up
Thanks for the replies. Photo as requested. I think I've spotted
Yep that’s the one open one inline with the pipe and slowly open the second till you hear water your looking for around 1.2 bar
Reply to Worcester Bosch Greenstar 30 CDi - Pressure loss in the Central Heating Forum area at PlumbersForums.net
