Discuss Worcester Bosch help in the Central Heating Forum area at PlumbersForums.net
A
Ayy Bee
I have a greenstar 35cdi combi boiler that when the thermostat calls for heat. It will fire up heat to temp and then drop down to 41* on the boiler display and then kick back in again.
I have checked all wiring and the zone valves. What else could it be? anyone seen this before
Reply to Worcester Bosch help in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
J
Hello, I have a Bosch 35CDi, and today found all the lights flashing on the front. Normally I can reset the boiler, but this did not work. There...
Deleted member 120897
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a...
