Discuss Worcester Bosch help in the Central Heating Forum area at PlumbersForums.net
A
Ayy Bee
I have a greenstar 35cdi combi boiler that when the thermostat calls for heat. It will fire up heat to temp and then drop down to 41* on the boiler display and then kick back in again.
I have checked all wiring and the zone valves. What else could it be? anyone seen this before
Reply to Worcester Bosch help in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
