Discuss Worcester Bosch system filter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Like I said boiler filters will be abundant .Alpha boilers have launched a magnetic filter integral to the pipe fixing jig ,which costs £140 but in return you get a additional 1 year warranty on top of the 5 year standard warranty
I think the likes of independent filter manufacturers will diminish as boiler manufacturers filters will grow as they will offer additional warranty to the boiler.
Like I said boiler filters will be abundant .Alpha boilers have launched a magnetic filter integral to the pipe fixing jig ,which costs £140 but in return you get a additional 2 years warranty on top of the 5 year standard warranty
I think the likes of independent filter manufacturers will diminish as boiler manufacturers filters will grow as they will offer addition warranty to the boiler.
Alhpha used to throw in a free tf1 filter... Maybe the filter makers & manufactures of boiler shud come together, because if boiler makers like Worcester come out with that mess of a magnet then there better off teaming up with a filter that is already developed and installer friendly.
I can tell you worcester have teamed up with adey to make the worcester filter .Worcester have created a filter which needs two spanners ,not good .I must say I like alpha's filter but it is too small in my opinion and will clog up very quickly .
Well Worcester would have been better off putting a magnaclean pro in the box.
...flow & return are a fixed direction, the valves rotate, but installation is only possible one way or there Is no access to iso valves..
I couldnt see that problem, fittings rotate 360 degrees so you can site it facing whichever way you like leaving the valves facing out.
Reply to Worcester Bosch system filter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just had a new Worcester Bosch Greenstar 30Ri fitted with the magnetic filter. When the system is running the boiler is so quiet but there is a...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
I recently moved into a flat with a Worcester Bosch CDi 35 Compact (or Classic System maybe?) and the thermostat on the boiler was broken (the...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
