Discuss Worcester Flue protection through wall with lime render in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Allgoode
Hi all,
I will be fitting a new flue to a Worcester boiler as the cement has munched through the old flue in a couple of places.
My question is there anything that I can wrap the flue with as it passes through the wall to act as a sacrificial protector for the new flue. I have thought about using ally tape which is the same material as the flue.
the wall had cement render which is in the process of being replaced with lime render as well so not to sure how that would interact with the new flue.
cheers,
Andy
Please don't touch the flue unless you're gas safe registered....which I doubt you are with a question like that!
Reply to Worcester Flue protection through wall with lime render in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
