Discuss Worcester grecnstar - changing the plate in the Gas Engineers Forum area at PlumbersForums.net
Jennie
Hi all,
I'm due to change my first plate on a Worcester Greenstar next week (not looking forward to it).
I found this on Youtube. Is it really as easy as this guy says? And what about checking/replacing the O-rings?
Any tips most welcome.
Jennie
Does the pipes go up the back of the boiler ?
Left hand hydro block out and bypass tube you will be fine
Replace the left hand as it gives you all the washers
Worst case you remove the whole hydro assembly eg the two transparent plastic clips, expansion vessel flex out of pump block and guage, slide the prv slider down and undo all the jig nuts and the whole lot will come out
87161072240
We do quite a lot of work on these and I always find it easier to just drain and remove the whole hydraulic flow and return sections in one. If it's over 7/8 years I always advise customer to replace plastic flow block, dhw restrictor and prv, cost £60 ish but massive saving in the future. Just take your time undoing everything and cover board etc with a towel.
Or a Cdi 20 mins and a left hand hydro block :D
Reply to Worcester grecnstar - changing the plate in the Gas Engineers Forum area at PlumbersForums.net
Hi I've just had my annual maintenance check on my boiler (in title), it will be 8 years old in May this year and is (I think) still under...
2K
Hi everyone, I have been searching the Web for a spare part for a Worcester 35 cdi ng boiler that is obsolete. I can't find one anywhere and its...
Hi guys... Happy New year to you all.... Been out to a Worcester Greenstar Combi last week.... Problems with hot water not getting very hot...
I have a 16 year-old Worcester Bosch Greenstar 35 CDi combi boiler, which is recently suffering from intermittent issues with the hot water. I...
3K
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
