Discuss Worcester Greenstar 29CDi Classic boiler in the The Welcome Wagon :) area at PlumbersForums.net
I have an issue with a Worcester Greenstar 29CDi Classic boiler.
I replaced the old thermostat controller with a smart dual-channel HIVE one.
I did all the wiring following the diagram in the attached picture.
The boiler doesn't work anymore.
Please, any suggestions?
Did you remove the old clock?
Picture of your wiring please
Of course, I did. The issue was that the diagram for wiring the HIVE thermostat to the Worcester combi boiler was wrong. Because I've used only the heating channel, the return live had to be connected to the com no 4 on the receiver's pins.
Anyway, it is sorted already, but thanks for your reply.
Glad you managed to get things sorted out in time for the cold snap we have had!
Reply to Worcester Greenstar 29CDi Classic boiler in the The Welcome Wagon :) area at PlumbersForums.net
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if...
PSxxxxxx
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
