Discuss Worcester greenstar 30 cdi internal filling loops in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hessyboy
fitting above boiler tommorow with pipes goin behind jig so looks like im going to have to use the filling loop supplied with charging key e.t.c. i usually just put a normal one on so easier for customer to use . Has anyone fitted the worcester internal filling loop ?? Any problems or are they ok ???? Thanks
Easy to put in the prefill links i use a normal now as you a lot easier to explain to custs how to do it, easy to do remove plugs from cold and return valves insert prefilll tighten 4 allen keys job done
I like to fit an external ones, as the worcester ones are a bit crap and I also like to add inhibtor through the filling loop aswell which you need an external one for.
If you like a normal filling loop just use a 22 x 15 x 22 and a 15 tee instead of elbows and fit it below the boiler. Bend it to the side and it will look better.
Thanks for the help guys only thing i found was everytime you take the key out you get a few dribbles of water but no problem other than that. Was going to do that Tams but had a heating pipe teed off the return going to a rad right near the boiler so it would of looked pretty crap any further down so stuck with the internal. Cheers
I install worcesters alot, have no problems with the internal filling loop. Easy to fit, just got 4 grub screws with a allen key and fits nicely.
However i dont take the key out because it does weep, so just keep it in, you fill the heating by the knob to the left of the key by unscrewing it with your fingers.
Only issue I have with them is when you turn up to a property and the T has been misplaced.
Reply to Worcester greenstar 30 cdi internal filling loops in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
