Discuss Worcester Greenstar 38cdi Classic Combi Minimum Flow Rate in the USA area at PlumbersForums.net
Hello there, I'm wondering if anybody can advise me, please. I'm in the process of switching my thermostatic radiator valves to Drayton Wiser valves. I currently have one radiator fitted with lockshield valves as a bypass, but I would like to put a Wiser valve on this as well and incorporate an automatic bypass valve into the system. My only problem is finding the information that I need to correctly set the bypass valve.
Could anybody advise me what the minimum flow rate requirement is for a Worcester Bosch Greenstar 38CDi Classic combi, or even better, advise me what the bypass valve should be set at, please? I have looked for the information, but I just can't find it anywhere.
Many thanks in anticipation.
Richard
I would leave it as a lockshield or fit an external bypass
Thanks for that Shaun, it is an external bypass that I am going to fit (I don't want to leave the radiator with lockshields), so I'm trying to find out what to set a new external bypass valve to.
Kind regards,
Richard
you set them under normal conditions with all the trvs open so there’s no flow through eg no heat and add half a turn / number so eg no flow on 2 you set it to 2.5
Reply to Worcester Greenstar 38cdi Classic Combi Minimum Flow Rate in the USA area at PlumbersForums.net
Sonya K
