- Messages
- 9
Discuss Worcester greenstar compact 30Ri burner. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
No hot water I meanNot sure if pump is working to be honest. The radiators aren’t warm and there is no water.
Is it just cutting in/out without having to reset?. if a pump fault, one might expect a low water level alarm or similar, if a ignition fault, I think some boilers make 5 attempts before lockout.No hot water I mean
The green burner light only goes on for 5 seconds after the boiler has been turned off at the mains. Every other time I try to put the heating or hot water on the burner doesn’t go on at all. There’s no faults. The blue light on the front goes on when you turn the heating/hot water on but nothing else happens.Is it just cutting in/out without having to reset?. if a pump fault, one might expect a low water level alarm or similar, if a ignition fault, I think some boilers make 5 attempts before lockout.
I should have said the father in law changed a couple of radiators the other day, could it be that there is air trapped in the system somewhere? All rads have been bled.Is it just cutting in/out without having to reset?. if a pump fault, one might expect a low water level alarm or similar, if a ignition fault, I think some boilers make 5 attempts before lockout.
Reply to Worcester greenstar compact 30Ri burner. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
