- Messages
- 34,366
- Solutions
- 2
right went to a call out today no hot water and a blown 3amp fuse,
just to let you know im not the first heating eng to be called out client said shes had 4 including me
worked out what it was (2 channel prog) and the link was missing in the hot water side so unless timer was on hot water 24/7 it wouldn't give hot water
sorted that anyway
fired all up good 10 mins running hot water then switch to heating etc fine, just about to go thought i better test it again so turn hot tap on and nothing bang fuse blown, put a new one in tried heating and nothing bang fuse blown,
managed to get it not blowing fuses, turn tap on nothing (boiler doesnt fire) pump runs thats it
so phone worcester up to see if i have missed anything so went through the questions overheat stat got power in and out etc, he said it should fire and if it doesnt it the control box (pic below) and also the cap is leaking
also this flashes (well one quick flash, one long flash about 1-2 seconds, then 5 seconds of nothing)
is he right (dont do oil much) or is there any funny or anything else that i have missed?
many thanks
shaun
ps any question ask away
sorted that anyway
many thanks
shaun
