Currently reading:
Worchester 24i shower issue cold
Discuss Worchester 24i shower issue cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
have had the 24i since we moved into our property 5 years when we moved in flow rate was rubbish so had the secondary HE changed, just before winter getting similar symptoms lose of pressure and intermittent hold cold issues , so replaced the HE again, solved all the taps and bath intermittent problems, shower was ok for a few days but now it’s cycling intermittent hold cold. All other taps and bath( which is on sale pipes as shower) are fine.
Any ideas? Thanks
Plumber mate did first, me and plumber mate did second one, he can’t understand issue changed shower mixer for me which made things a bit better for a while , my only thought is the mixer is scaled up and not “calling” for hot water.
Well I’m sure you can appreciate we don’t give DIY boiler advice to non gas safe engineers. If he’s struggling get him to register on here and we’ll lend him a hand
Here you go
Just to clarify it’s not the heat exchanger in the actuall boiler it’s the one at the bottom at the back dhw? I think .. apparently they scale up in hard water areas really quick
Yep. And just to clarify you had to take the case off to get to the plate heat exchanger. This means you have to be gas safe registered mate.
I’m thinking the issue is with your shower mate, if all others are ok. Could be the inlet filters if you live in a hard water area, it could also be a thermostatic valve replacement, or even a collapsed shower hose. As for the boiler, I’d leave it well alone unless GSR.
Reply to Worchester 24i shower issue cold in the Plumbing Jobs | The Job-board area at PlumbersForums.net
