Discuss X800 - x400 or F3 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
c.gas
Which would you guys recommend for the job, got an isar that's got a partially blocked main heat exchanger as you can hear it whilstling when you run ch or dhw. My plan was to try a cleaner in it and leave it for a couple of days as the customer is home for a day on Tuesday and then back on Thursday so can go back and drain it. Is x800 to aggressive to leave for that long as don't want to kill the heat aluminium heat ex
Would not personally put X800 in,would talk to them about changing TBH a ISAR is a reight heap
I agree but customer wants to try the cheaper option first so it's not for me to decline really
x800 only works for 24hrs max, x400 would be better (this is from sentinel tech reply to a question i asked). both wont attack the HX. F3 is good, F5 is stronger but not sure on its lifespan.
Just cover your backside, tell customer that you can add a cleaner if he wants to risk it, let him decide.
These chemicals very rarely help a hex. I had some success yonks ago helping a friend of mine out who had absolutely no money at all Took the hex off his old halstead and we painstakingly swilled it through with a strong acidic cleaner. Not the perfect scenario I grant you but he was happy when the boiler work properly again
Yeah I've done that myself on a Heatline Vizo using one shot drain cleaner and it worked a treat, don't fancy taking the heat ex out of an isar really
Reply to X800 - x400 or F3 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an old Glow Worm Fuelsaver 40B Mk 2 installed on the kitchen wall. In November, the heat exchanger began making a kettling noise. It’s...
2K
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
1K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hello, BEFORE I cleaned the system last year with a mains flush. There was a little inky stuff and a bit of sludge at the very end when I emptied...
5K
Morning all, I've recently cleaned my F&E, microbore central heating system using Sentinel X400 and this led to the cold rads heating up again...
8K
