Discuss XPress fittings, pros and cons. Opinions please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 96286
Hi, looking at getting into press fit fittings as I like the speed that they can be installed on copper, and without a flame, or a big ugly plastic or compression fitting. They look great and earth continuity is maintained and are tamper proof on copper. The fittings are also inexpensive.
Apart from the expense of the press fitting tool, I'm looking for pros and cons of the press fit system. I'll only be using 15mm - 28mm.
Opinions please, before I spend my cash.
Hire the machine for a few week and see just how much you use it and what you think. They aren't that much to hire, so well worth trying it.
Keep me posted I'm interested to see what you finally go for.
I have used press fit on a couple of charity days , and to be honest I was blown away on how good they are.
I am a well publicised tight arsed old yorkshire man and probably wouldnt invest , 10 years ago I should have . That should tell you something.
However I can solder in areas you would not be able to press .
All good, have used them for a good few years now and can't fault them.
I have a REMS machine and use up to 2inch, well worth the investment.
I would also recommend you invest in the proper pipe cutting tool, have a look at the REMS website.
Bob
cento?
i like them they are neat don't discolour copper (no heat), no flux. they are not cheap but not far from plastic pricewise so you have to check prices before you quote, can be used on water and gas (with appropriate gas ones). and you nead to plan jobs as you need good access to press joints.
I've ordered in about £150 worth of fittings in 15mm and 22mm, which should be used up fairly quickly. As a price comparison, they are roughly about the same as Hep2o fittings and more expensive than Speedfit and end feed.
They just look good and are also something that can't be tampered with by diy'ers and are a form of pipework that only professionals will take on, mainly due to the cost of the pressing tool. I'll post up a review in a few weeks after I've given them a thorough test.
I was advised to look at getting the tool through Hilti Fleet as it would cost about £35 per month including servicing and free upgrades to the latest model. If anyone has experience of this service, please let me know your thoughts on it here.
Reply to XPress fittings, pros and cons. Opinions please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
