Discuss Zero water pressure on boiler gauge in the Central Heating Forum area at PlumbersForums.net
Gas boiler shows No Water Pressure. The water feed to feed the system doesn't move gauge. Water dumps overboard. A banging noise starts when the valve to top up the system is opened.
If by 'overboard' you mean the pressure relief outlet (outside) or from somewhere inside the boiler casing there's nothing you can legitimately do for a DIY fix. You'll need to get a Gas Safe Registered heating engineer to sort it out for you.
The pressure gauge could be faulty. Pressure may have dropped over time (or discharged after going over pressure) and then the gauge needle got stuck. Adding more water when it is already up to pressure will eventually bring it to 3 bar and that will open the pressure relief valve dumping water through the discharge pipe. Alternatively the system may have gone over pressure and discharged leaving the pressure relief valve jammed open which is passing any water you add to the system.
I'm afraid it's time to call out a plumber who is registered with Gas Safe.
Thank you Stigster. Overnight I kind of came to that conclusion, so hopefully it's a duff gauge. As pennies are tight I'll live with that but will have a service done which is well overdue. Due to advice on this forum I'll have some idea to counter 'You need a new boiler mate' As I say, pennies are tight. Thanks again.
Reply to Zero water pressure on boiler gauge in the Central Heating Forum area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
I have a Worcester Greenstar gas boiler circa 2017. There has been a noise coming from the boiler which resembles running water, I have checked...
Hello. Today I have installed a new radiator upstairs. A little bit bigger so I had to make new pipe work. Before that I flushed as much water...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
