Discuss Zoning my in the DIY Plumbing Forum area at PlumbersForums.net
I am looking some information on zoning my house the set up I have now is funny one But I have two pumps that pumps water to the rad and too hot tank. When I switch my boiler to hw the pump is wire to the bolier but it heats four rad downstairs when I want just hot water. My other pump witch has a switch on the counter heat one rad downstairs and there a second switch that turn on a valve to send heat upstairs. So I want to zone then to a nest but I don't want heat hot water every time I turn on the heating. Aslo in my bathroom there is a stud wall that is build of a block wall and I think that has the pipes going up to the hot tank as the tank is above it and to my rad because been a while from I was in an building of a house but there is a place were the pipes meet each other
Sounds like you need to s plan the system eg two 2 ports
Thanks for the reply the lay out is mess up so I need to get where all the pipes are at and see if I can change the setup as have all the downstairs rads on one line as the way with upstairs and hot water on its own line aswell would that upset the system. We have a firebird super q boiler yeah it's old. But will wait to it has enough then change
Here is the layout at the boiler
Reply to Zoning my in the DIY Plumbing Forum area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
