Kitchen Tap (same issue as previous poster)
View the thread, titled "Kitchen Tap (same issue as previous poster)" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, my kitchen hot tap (mixer tap) has low flow compared to the bathroom upstairs and to the cold side in the kitchen.
It was fine a while back but we had a leak and the flow to the taps was isolated and ever since its been really low flow.
The boiler is a Atag ic econ 27 combi.
I have checked the isolation valves on the hot side and they are fully open under the sink, exactly same as the cold.
Any ideas? I don't know what else it could be .
Thanks in advance
Yes it's fully open and the same mixer tap on the cold side has normal pressure.
Is it possible the isolation valve is partially blocked or the mixer tap on the hot side has an issue?
I'm not sure where to start troubleshooting.
If it’s just the hot tap on the kitchen sink that’s low pressure / flow either the cartridge or something connected to the line
Flexi kinked ? Etc
Reply to the thread, titled "Kitchen Tap (same issue as previous poster)" which is posted in UK Plumbers Forums on Plumbers Forums.
markfrommanchester,
markfrommanchester,
