Can’t understand why we can’t go down the permit route and use building control as inspectors will give more a job also hopefully would cut down on any problem/ unregistered installs as everything would be traceable
I can't have a garden tap as landlord says no.
However, I do see lots of people have indoor taps that have a nozzle that screws off and I could then attach an adaptor and hose - I think they are called removable aerators.
It would be...
If the radiator is slightly oversized it should not a problem as the controls for the heating system will restrict heat when the conditions are satisfied.
For example when your thermostat has reached the set temperature it will tell...
Yes normally find the condense is backing up slightly / boiler tilted the wrong way causing a drip onto the blast tube
Grinder and a wire wheel sorts them out
I’ve had trouble taking off the new blast tubes from the low nox burners for a while now, usually on the new grant euro flame/vortex oil boilers. Some of them are fine and come off easily and others barely budge at all. The pictures are...
[title}
Please checkout thew design on our gas community. www.gastalk.co.uk/bb Please register for free. - no ads - brand new no cliquey members - be part of growing the network
Continue reading on Gas Talk Facebook Page
Check the boiler's MI's, they probably won't 'allow' a one-pipe system. Even if they do OPS were traditionally designed for 75 or 85°C operation (and no TRVs) so the boiler probably won't be able to work in condensing mode, which will...
It's like the flow and return, is a loop one pipe system is still flowing through the old not in use back boiler. The 15mm that drops down is the main loop for the one pipe circuit still
Thanks it's a house someone has bought. With the stage there at now I have recommended changing/repiping to a 2 pipe system. It's on a combi a moment a 2 year old gloworm
Been to look at a job, somebody has bought houses wanted a radiator capping off and a radiator moving. System is on a combi. Is an old one pipe system though. With the pipe runs etc I have advised repiping to a 2 pipe system. Pipes come...
No you don't have to be gas safe to do that so long as the flue is not disturbed, in my humble opinion.
No other engineer in 20 years has said anything? It could do with one by the look of it but if it is solid, I can see why it...
Has that flue exhaust always pointed downward?
Personally I would have brought the flue further out and used a plume kit to take it upward. I have not seen what is above the facia?
Hello,
My friend bought an old bungalow last year, and it has a pretty outdated plumbing setup. He is looking to overhaul it urgently. It’s a combi boiler with a hot water storage tank (unused by the looks of it) and another tank in...
No more ply have their own adhesive in a tube / sealant gun tube and then the screws is what I have used that in the past. It’s relatively easy and quick.
Hello,
In my kitchen got a leaking elbow joint between an old original stopcock and another newer stopcock which was fitted later at some time. The old stopcock also has a tiny trace of leek where the handle spigot turns so this...
That’s a strange one!
If the outside tap still runs a bit even after shutting off your inside and street mains, there’s a chance it’s been plumbed into something unexpected maybe even tee’d off a shared supply or an old bypass line...
