Washing Machine Tee Isolation valve
View the thread, titled "Washing Machine Tee Isolation valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
I've been to several plumbers merchants trying to find out if a washing machine Tee valve with a built inn check valve exists. All have said no so I thought I'd ask the question on the forum.
Thanks All
It's unlikely that they exist, but if they did they would be very expensive.
Can you not use a normal Tee with a close connected Washing machine valve with a check valve included?
Reply to the thread, titled "Washing Machine Tee Isolation valve" which is posted in UK Plumbers Forums on Plumbers Forums.
Tezzer2022,
ShaunCorbs,
