Air Admittance Valve or Roof vent?
View the thread, titled "Air Admittance Valve or Roof vent?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
K
KingK268
Doing a split level custom build. The plumber wants to install AAV's on some of the lower level lines, a bathroom and a bar sink. There is a way to vent them normally through the roof, it's just more work for him. Which is better? The floor above hasn't been cast and a vent can come up through the floor to meet a wall that can be stacked to the roof
What kind of roof?
Personally I'd go AAV as long as you can get to them to replace one fine day e.g. don't tile in. Wooden tops to cabinets? Gives resilience to put things down on.
Cheers,
Roy (amateur)
Running a traditional vent pipe through the floor and up to the roof is generally better and more reliable than using AAVs. Since the floor isn’t cast yet, it’s a good time to install proper venting that meets code and avoids potential failures of AAVs.
Reply to the thread, titled "Air Admittance Valve or Roof vent?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
KingK268,
snowhead,
