I am currently installing four radiators as a favour for a friend in an office building of 3 floors – the rads are required on the ground floor. The heat for the building comes from three boilers connected in series. (All hot water is provided by several multipoint water heaters). Three branches of pipework run to each floor from the boiler-room (on the top floor) and each has what I understand to be an ‘acctuator’ connected. The two actuators connected to the ground and top floor are fixed in the OPEN position and are not affected whether the boilers are switched on or off - I can see no purpose to their installation.
The actuator for the 1[SUP]st[/SUP] floor, on the other hand, switches to the closed position when the boilers are turned off. I am confused as to why only one of the actuators operates. Also the operating actuator looks to be out of alignment in the open position. Additionally, because this actuator closes when the system is switched off prevents the 1[SUP]st[/SUP] floor supply from being drained.
I would very much appreciate understanding the purpose of the actuators. Thanks for any help.
Please note that it is the orange actuator that serves the first floor.
