View the thread, titled "10mm or 12mm bore tap connector" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
NedRack
Hi all
I am fitting a new en suite basin with new taps using flexible tap connectors with isolating valves. Should I choose connectors with a 10 mm or 12 mm bore?
Cheers
Ned (DIY)
full bore isolating valves and if your using flexi pipes you can get 13mm if not 12mm is the next best thing, (use isolating valves and flexi pipes not flexi pipes with isolating valves as they are restricted flow valves)
Reply to the thread, titled "10mm or 12mm bore tap connector" which is posted in UK Plumbers Forums on Plumbers Forums.
