it measures 10bar"...but the pressure from 10mm will cut concrete."
Better use steel basins then. 😄
I cobbled together a system using a regular pressue guage, some tap connectors and a valve. It has a push fit connector to swap between 15 to 10mm pipe. So I can measure static and working at any outletWhat method of measuring pressure is giving you a reading of 10 bar?
but I have no issues using a combi and a continuous water heater simultaneously lol. This is what I'm getting from the mains as I removed the PRV on the MDPE feed. I'm now going to have to modify the pipework to add a new 15mm line to provide the entire house with cold water and I'll be adding a PRV to this line so as not to interrupt the flow the the heatersIt's often used nowadays bud pressure wise 3 - 6 bar is not unusual for mains supply,10 bar seems a bit high ??
instructions are that if pressure is over 18 bar (combi and WH) then it needs dropped down. (they also accept propane/methane without any modification and can be placed outside without protection unless the temps drop to -20) (other than a dip switch)). Push fit fittings far exceed the ability of copper solder joints to withstand pressure. 3 bar gave a flow of 8 l/min which is why I had to experiment. I initially thought I would have to install a pressurised water tank to keep up with flow demand . I have had a single pushfit stop end pop but that was on the hot water supply. It was of those with the steel teeth so cut and swapped with JG fitting and no problems. I swapped out the old toilet cisterns with quality Gerbit sigma who are good for 10 bar on the data sheets.I am not disagreeing with you but please be aware high water pressure will damage your water heater and combi , your manufacturers instructions will guide you, prv 's are fitted for a good reason many plastic components are used in boilers ,water heaters , toilet cisterns flexible tap connectors these are not designed or manufactured to with stand 10 bar working pressure it will cause abnormal wear and tear , resulting in a failure and severe water damage to your property ,which you may possibly be not covered for at that pressure. My advise would be replace the prv and adjust it to 3 bar working pressure 21 litres a minute this should be a good average pressure . Kop
Reply to the thread, titled "10mm pipework for cold water..why not?" which is posted in UK Plumbers Forums on Electricians Forums.
