dazplum
HI all after some advice again please.
If a customer wants an additional rad and you notice the pipework nearest to tap into is a rad supplied in 10mm, would you tap into this or suggest you run back to the manifold pipework, where you could tap into a larger pipe?
Problem is sometimes I have no come backs with 2 rads on 10mm, then sometimes, you no the rest:wink5:
