View the thread, titled "15 mm fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
davehughes
Hi
Does anyone know if there is a compression coupling that joins the old 15mm BS864 to the new 15 mm en1254-2? threads are slightly different.
Thanks all.
i thought that was the case but i tried to avoid it as i have to drain the central heating system, no room to freeze pipe. Not the end of the world.
Dave
Reply to the thread, titled "15 mm fittings" which is posted in UK Plumbers Forums on Electricians Forums.
