View the thread, titled "15mm cold supply feeding two bath rooms" which is posted in UK Plumbers Forums on UK Plumbers Forums.
On a house that is plumbed up in 15mm pipe for the cold mains. Feeding a bathroom and an ensuit next to each other. Would the shower in the ensuite not likely struggle when some one is using the bath in the bathroom next door. Are both feed of the same 15mm pipe.
It all depends what sort the of pressure at the mains is and how long the runs of 15mm pipework is ... As well as how old the installation is because of hardened water could scale a lot up.
James, depending on your hot water , gravity / combi etc , that could be more of an issue .
guessing teeing of the main 15mm run separately for the ensuit and bathroom wouldn't make any difference? Is that correct? Than teeing off once to pick both up if anything that would give a longer pipe run.
Ideally would run 22mm from the stop tap although the water main to the external stop tap could be 15mm or equivalent I/D
unless you are happy to ensure you have a 35mm mdpe cold main into the house and then run a 22mm cold feed around the house, just live with a 15mm set up as it is.
Why would I need a 35mm mdpe supply. Couldnt a 22mm cold on the.first fix be.used.off a 25mm mdpe supply. And its a 30kw combi so will likely struggle on the hot water.supply anyway.
Why do you not just take pressure and flow rates from taps and then discuss with customer there usage and make a informed decision on this? If can be replaced from stopcock in 22mm relatively easily without too much damage then recommend this to customer but ultimately give them the relative information and then let the customer decide how they would like to progress?
Any anyone explain this teeing off the 15mm cold separately for the bathroom and ensuite wouldn't make any different as its only 15mm pipe you are drawing from. Would make a difference if the main run was 22mm though?
your the one panicking about cw supply flow rate and pressure, just offered the best option............
Reply to the thread, titled "15mm cold supply feeding two bath rooms" which is posted in UK Plumbers Forums on Plumbers Forums.
