J
jfk
Hi I have 2 radiators upstairs in my house, running of a gravity fed heating system. They used to work untill recently. I have bled them and theirs water in both. I tried removing the rads and pulling water through each pipe using a hose untill hot/clear water came through, when I re attached the rads and filled them they heated up for about 5 mins then went cold. The radiators did have alot of thick sludge in when removed and I flushed them through with a hose COULD THEY BE BLOCKED Up?. I also tried shutting of the rads in the other rooms to force the heating their wayth no effect. They are not trv's. Do I need new rads or is their something else I can try??
Cheers J
Cheers J
