got a problem with this boiler, nothing is operating whatsoever and its flashin red around once per minute.
I'm the 3rd guy to have a look at it, its for my auntie's tenant. First guy changed gas valve, 2nd guy changed PCB still the same.
I have tested the water pressure switch with my multimeter and I'm getting continuity, took it out and cleaned all the sludge from it, checked the overheat stat also fine, I am getting 240v to the PCB but no power to the pump.
No continuity at APS, not sure if that's what i should be getting or not been a while since I've attempted any repairs.
To me it sounds like the PCB isn't sending signal to pump, but the PCB is brand new so I'm stuck
