View the thread, titled "3 flats water supply" which is posted in Bathroom Advice on UK Plumbers Forums.
M
mark_mc
have a wee job coming up to do 3 flats at home. each flat to have a combi boiler fitted
went to the job to turn water off to the building and there is one stopcock 15mm and thats it.
so i cant run three combis off a 15mm mains pipe must be 20mm mdpe coming in.
so i would have to upgrade or get 3 different water main connections in?? or have any done it differently?? many be a break tank with a booster set
any ideas.
Would prob be a better idea to get 2 more supply's due to the arguments over bills
Booster set and breaktank may cause more issues with a very poor landlord who doesn't keep up maintenance and poss risk of freezing
Hi. Infrastructure charges for tapping a new supply can run into a grand or two. Check it out with the local water company before putting to much work in. As the client may well change plans. Good Luck
Reply to the thread, titled "3 flats water supply" which is posted in Bathroom Advice on Plumbers Forums.
