View the thread, titled "3 port valve - which way is flow?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
K
koiman
Is there any standard convention for which ports of a valve are open in relation to the flat on the valve spindle?
I have a 3 port zone valve (unknown make/model), controlled by an actuator. The actuator linkage broke and, now that I am replacing it, I can't fathom out which position it should be in? When the flat on the spindle points to a port, is that port open or closed?
Thanks.
OK I think I've worked it out by trial and error. For this valve anyway the flat on the spindle points to the port that is closed.
OK I think I've worked it out by trial and error. For this valve anyway the flat on the spindle pints to the port that is closed.
Doing my apprenticeship in the Black Country was taught "A fer yer 'aytin B fer boffrooms"
Reply to the thread, titled "3 port valve - which way is flow?" which is posted in UK Plumbers Forums on Plumbers Forums.
