View the thread, titled "3 port valve ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Mugwuffin
Hi Guys, just got a call to look at a Remeha Avanta 18V tomorrow . Homeowners had no hot water or heating for couple days now, boiler is displaying an E4 fault code but the Danfoss HSA3 motor valve is "damp". Just looked up the MI and can't see how an E4 code would tally with a knackered 3 port ? could there be a short inside the valve upsetting the boiler ? Thanks in advance !!
This'll be two separate problems. Won't be able to help you out anymore on the gas side of things.
Well, the Mi says it could be a gas issue, I'm GSR but have only done installs not faults to date, how do i register as GS with the forum ? Cheers
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. I'm looking for a Plumber or Gas Engineer
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/ce...ed-advice.html (notice gas safety related advice)
Thank you.
Thank you croppie 🙂
Reply to the thread, titled "3 port valve ?" which is posted in UK Plumbers Forums on Plumbers Forums.
