View the thread, titled "3 port valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
plumben
Ive got a job on tomorrow to fix a 3 port,
It's already had 2 new heads on the valve and needs a new one,
Would you fit a new head or whole new valve? Just wondering what everyone else would do?
Theres 3 gate valves and a pump valve that I can isolate the water by so no need to drain although the header tanks just above the valve anyway
Carefull with the gate valves. If they are the cheap ones if may take longer to replace them, than the motorised valve.
Whole valve as its already had 2 heads probably tells you something , bung it instead of risking using the gatevalves
Whole valve, I'd suspect the spindle is stiff & killed the old ones... Check the pipework of your changing it because of rads getting hot on hot water etc...
I had a quick look at the pipe work it all looks fine, nothing jumped out, I'm fairly confident in saying that the valves jammed/stiff hence why the CH is on with hot water, I'm fairly certain that the systems sludged up aswell
Whole valve, use bungs. Did two zone valves and a diverter today without draining or using carp gate valves.
I just drained the header tank and tied the ball valve up, and stuck a wet vac on the air bleed for the last little bit
For anyone who's interested this was the fault as I suspected, stiff spindle killed the motors off valve was seized solid in the mid position
Thanks Plumben, its always nice to hear how things work out. Not enough threads get there proper conclusion.
Reply to the thread, titled "3 port valve" which is posted in UK Plumbers Forums on Plumbers Forums.
