Guest viewing limit reached
40mm waste Connection issue
View the thread, titled "40mm waste Connection issue" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
Novice
Hi Everyone,
I am doing some diy and need to figure out how to connect a 40mm waste pipe to a very large round plastic water-tank, i have no idea what the best connection method would be and can't seem to find a connector available, I have tried google but came up with nothing so far
thanks for reading everyone
Gezza
its a header tank, sorry dont have pics as nothing is in place at the moment sorry
40mm wastepipe on a header tank? Is this for a pond?
sorry its not for a pond its for a large round tank(cylinder Type),so I cant use a normal flat/straight walled surface connector any better suggestions, now that I hopefully have explained a bit better ? similar to the pic that i found on the internet only I'll be attaching on the side wall if that makes sense, I don't wish to connect anywhere else before you suggest!thanks everyone
One of these any good then?
https://www.NoLinkingToThis/p/mcalpine-mechanical-pipe-boss-connector-black-40mm/55722
Flo
Try the one in the link above or look at Mcalpine
The image you show in the Floplast push fit link will not work as you know that is for fitting on a flat surface...thanks though for offering help. But in this case way off the mark..but yeh macAlpine looks like a better fit even though its for 110mm
Reply to the thread, titled "40mm waste Connection issue" which is posted in UK Plumbers Forums on Plumbers Forums.
Novice,
ShaunCorbs,
