UK 50mm bath waste overflow
View the thread, titled "50mm bath waste overflow" which is posted in Bathroom Advice on UK Plumbers Forums.
UK
I've become aware that my bath has been leaking from the drain fitting. It looks like a botch job, loads of silicone everywhere. I took the overflow fitting off to see what size hole the bath has. It appears to be 50mm which I think is unusual. The current overflow pipe is much smaller and most of the hole in the bath was just filled with silicone. I'm sure I'm going to find the drain is a similar situation and probably why its been leaking.
I'm having trouble finding the correct part to replace this with, any advice or suggestions? Thanks in advance.
Reply to the thread, titled "50mm bath waste overflow" which is posted in Bathroom Advice on Plumbers Forums.
mikerbice,
ShaunCorbs,
