View the thread, titled "6" Hole in Floor under sink unti is the waste water system." which is posted in Bathroom Advice on UK Plumbers Forums.
Pipe Bend
Hi Plumbing People ,
I'm looking for some sound advice from you knowledgable people regards the following :-
We are preparing to upgrade the kitchen in a 70's built bungalow.
Opened the kitchen unit door to check out the sink plumbing and waste and found - attached photo.
Waste pipe - from the sink just sticks into a 6" open hole in the floor .
Looks like the top of a black plastic fitment -but it don't seem to be a 110mm as it's 130mm width inside the opening & 147mm accross the top .
There's also no rubber retaining ring -just a gap where I assume it perhaps should be .
Then with what looks like a " dropped into the hole " internal rubber reducer with the sink pipe stuck into it.
So - it's not quite up to standard.
I would be looking to fit a 110 pipe boss with waste soil / access points - but is what we see the top of a 160mm pipe fitment or if not what is it ?
Any Idea's would be most apprecaited.
Hi Snowhead :-
Thanks for the quick resply .
If as you suggest it's the top of a 150mm coupler - would you know if there is one of the following available.
a/ male 150mm to female 110mm reducer - to fit into the existing
or
b/ 150mm female to 110mm female reducer - to replace the existing
Reply to the thread, titled "6" Hole in Floor under sink unti is the waste water system." which is posted in Bathroom Advice on Plumbers Forums.
