View the thread, titled "60 kw boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Patchie
Hi all can i fit a 60kw boiler, I am gas safe but only domesitic, its for a very large privite 6 bed house with possible celler convision to be added, also would i need to check gas meter size and what size should it be? thanks.
the number on the meter code refers to its capacity therefore a u6 passes 6 cubic meters of gas rough estimate is 1 m3 for every 10 kw so with a range cooker as well youl need to go up to a u16 meter
i think 70kw is the limit on domestic but id check that with kirk
as said you could fit two boilers in tandem
Patchie ...It doesn't realy mater whether you can fit it or not, it matters whether you are right for the job? You'll always encounter work that is more porvent for other more experienced! IMHO
I agree with Diamondgas , if you arent 100 % sure i would not touch it , I was asked by my local church for a quote for a new boiler , 4 inch pipework etc ,i only do domestic stuff so declined
Thanks for the advice, i considered using the 2x 30KW, but lack of space prevented this. I've decided to go for an Ideal evomax, and an S-Plan plus system.
Diamondgas, I've been a gas engineer for 17 years, and untill two years ago was a mechanical engineer site foreman for a large domestic/commercial company running up to £500K contracts, two years ago I set up my own business. After working for 16 hours yesterday and then having to do this quote my brain was frazzled and I was after some confirmation (or not!) before emailing it over!
Gasmarc, I did a church last year, boiler, up to 4" iron pipework and underfloor heating, it was cold when I started, hot when I finished, I think God loves me!
Nice one Patchie , May i wish you all the best , It sounds like you have put the ground work in so time to reap the benefits ,Good Luck to you
Id recommend that. I'm pretty sure that because it is refered to as a commercial boiler
If you do go with commercial thou rhemea Quinta would be the better option
Reply to the thread, titled "60 kw boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
