View the thread, titled "9/14CBi boiler firing up and switching off immediately" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Sarah H
Please can anyone help.
I can hear the ignition sequence working and then the gas firing up but then the whole thing shuts down. It then goes through the same routine again and again but never stays on.
Any idea's Please
Sarah
Go to the gas safe website type in your post code and select an engineer to assist your needs as it appears to be more than a DIY job
Any idea's Please
Sarah
Sounds like it's not rectifying. However the Boiler needs to be checked to confirm, follow quality's advice or call BG
Thanks for your advice all.
I have since checked the PCB and noticed one resister burnt out and water marks on the board.Perhaps a new one will fix the problem.
Any advice on where to find one please
Many thanks
Sarah
Just done one of these with the same problem, give your gs number and i'll tell u what it was. If u ain't gas safe then get someone in as you need to know what u are doing.
Sent from my MB526 using Tapatalk
No not a gas safe person just thought i could put on new board quite safely.
Thank you
Sarah H
Reply to the thread, titled "9/14CBi boiler firing up and switching off immediately" which is posted in Boiler Advice Forum on Plumbers Forums.
