View the thread, titled "90 degree bend soil pipe - pic attached" which is posted in Boiler Advice Forum on UK Plumbers Forums.
dholi85
Hi All,
I'm redoing my bathroom and needed alittle help.
As I'm building a vanity unit, the toilet will now sit 30cm away from the wall, so therefore I will need to extend the grey soil pipe. I didn't want to use a flexy pipe, so I thought would use a 90degree bend to join the two pipes together. I've had a look in screw fix and toolstation, the only ones I can see on are 92 degrees. is there a reason why they dont sell a 90 degree soil pipe bend?
will 92 degree be okay? What should I do in this situation?
It will be fine it will be hardly noticeable but is there to help you put a fall on the pipe.
Reply to the thread, titled "90 degree bend soil pipe - pic attached" which is posted in Boiler Advice Forum on Plumbers Forums.
