Had a quick chat with a mate yesterday about the following, could someone please clarify...
- If there is hot water but no central heating (or vice versa) is it more than likely the diverter valve? Poor hot water could be the plate heat exchanger?
- How do you check for earth continuity on a boiler? Power off, one multimeter pin on earth and the other on the boiler case? Not had much experience with electrics.
- How do you test polarity on a boiler? Check between L & N and then L & E, fault present if below 240v?
- Before work is carried out on an appliance do the following tests ALWAYS have to be carried out?
Earth continuity (dead test)
Short circuit (dead test)
Resistance to earth (dead test)
Polarity (live test)
Help with these questions would be great, thanks.
