View the thread, titled "A Water problem!" which is posted in Bathroom Advice on UK Plumbers Forums.
SMD
Both my upstairs and downstairs toilets are filling up very very slowly and now my shower is just giving out HOT water no matter how much you adjust the dial so im thinking that there must be a blockage in my cold water pipe thats feeds all these.
Where would be the best place to start to look or how is best way to go about finding a solution?
Thanks in Advance Steve
I would be looking at the tank in your loft(assuming it is fed from a tank as you dont mention your kitchen tap) could be a blockage in the tank itself or in the cold feed pipe.
As above. See if the water in your cwsc is warm. Or feel the pipes to your wc's, maybe they're warm. If so, your shower valve may be letting by on the cold side- hot water displace cold-airlock-faulty valve?
Sorry everybody that I have taken so long to reply but yes the water to the toilets is fed from a cold water tank but I assumed the shower was mains fed.
I havent taken the shower apart yet so im not too sure. The shower problem has only just happened so I was thinking it might be connected to the toilet problem.
the only way i can see the cold fail but hot not is if the shower were a power shower with two feeds. which would then mean same problem as toilets.
It must be an airlock on the cold. If you flushed toilets together or had shower running and flushing the same time it could've happened then perhaps.
I don't know how I got faulty shower valve, I read that toilets were giving out hot water????
Reply to the thread, titled "A Water problem!" which is posted in Bathroom Advice on Plumbers Forums.
