T
traineedrip
called out to a blocked toilet, nothing physically blocking the pipe but water backing up in pan. Has an indoor short soil stack next to W/C. removing the cap and activating the aav manually and the toilet empties perfectly. letting the valve rest on top of the stack without cap and it bounces up and down letting air in but valve wont open.... so theres some pull through the pipe when flushing.
Valve seems clean and not stiff, cant really understand what could fail on it.
Got onto hunter plastics, who suggested replacing it but couldnt offer any explanation as to its failiure. its an s450 aav 110mm.
So, how often do these things fail? why? and is it possible its something else is causing the poor drainage?
system has worked fine up until now, top of stack is about basin height and theres 2 basin wastes also sharing it... which appear to be fine.
