View the thread, titled "ACO 27 rffi - Display Flashing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
MarkM
Hi, A weird one?
My ACO 27 rffi has deveolped an anoying problem. The display is constantly flashing, I'm not entirly sure when it started, but within the last 2 months. The display flashes with a capital C followed by the water temp, ie C60, normally it should have a static temp?. The flashing is every one second on/off, if that helps.
MTS help desk advise that this could be the flow/return valve, whatever that is...
Here's the thing. If I move the Temprature adjustment knob from 3.5 to 4 and back to 3.5, then the flashing stops, for a while. Maybe it stops for 10mins or 2 hours, but the flashing comes back.
History: The system and bolier are only 2 1/2 years old, so everything is under warranty. Boiler anually serviced, now on service contract with BG.
Other problems, related? The Central heating is loosing pressure. I tracked one leak to an automatic air valve in the loft, this is now closed, but I'm still loosing about a quarter bar over a week. I've lifted most of the ground floor floorboards, sods law says the leak will be in the last room. Could it be in the boiler itself?
Any comment appreciated.
Mark
ariston aco=crap combi fitted 3, 4 years ago never again,combi or system just as bad as each other
Reply to the thread, titled "ACO 27 rffi - Display Flashing" which is posted in UK Plumbers Forums on Plumbers Forums.
