View the thread, titled "Additional isolator valves on shower pump pipework?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
R
realstokebloke
A quick Q. about isolator valves anyone please?
I am installing a Salamander ESP 100 negative head twin pump for a new ensuite shower.
Many kind souls have helped clarify what i need to do ref an additional CW tank for the required capacity - thanks.
But am a little in the dark re the need for any additional isolator vales on the pipework to / from.
Do i install a set of isolators to each of the x2 inputs & each of the x2 outlets to / from the pump itslef?
Or, as the x4 flexis in / out of the pump have isloators on them already, are they sufficient?
Also, if i do use additional valves (in JGSpeedfit PEX barrier pipe), would i be better using 'ordinary' isolator valves (metal compression ones with soft copper olives) or the actual Speedfit ones plse?
(I see that Speedfit ones are a lot more for the same job but might be far better in the long run.)
In theory, isolator valves on everything that moves are a good idea i guess but equally, every joint is a leak risk i suppose?
So what would you pro's do?
Thanks.
If you're unsure about the plastic isolation valves on the pump doing their job or failing in the future which is possible I'd fit two full bore isolation valves on to the pipe work going to the pump, one near the flange for the cylinder and one by the cwsc.
I am here: http://tapatalk.com/map.php?wlik2v
I totally agree with whats been said, I don't like those plastic iso valves and always put in the full bore quater turn iso valves,
To hell with the expense as well, I never use gate valves because we all know how rubbish they are.
from a grundfos engineer friend he told me in there instructions it states to only use full bore and if not if they are called to one of there pump failure the wash there hands with it ! he did give me some complicated formula to work out the restrction it caused etc etc making the pump work harder but i quickly "lost" that piece of paper somwhere
Reply to the thread, titled "Additional isolator valves on shower pump pipework?" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
