Im fitting a new bathroom and am after some advice. As you can see in the pictures the current floor is a mixture of 18mm chipboard and OSB board. Im installing underfloor heating and then tiles on top. What should I put on the floor as ive read lots of conflicting advice? Does it need additional plywood or some kind of cement board on top OR can i just put some 6mm insulation board on top of the existing floor? the current floor isnt bad but the OSB board does flex a bit if you apply a lot of pressure.
Second question is about the shower tray - the instructions say that needs to sit on sand and cement mix on top of ply but it seems common to just use building adhesive instead these days?
Marc
Marc
