View the thread, titled "Advice needed choosing a new boiler for work ?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
clrky501
Hi-looking for some unbiased advice please
I am the admin manager at work an I need to look at replacing the boiler as its 15 years old and would like some advice.Its a system boiler.
Just wondering what the best boiler would be-we currently have a system boiler but wondering if a combi is o.k to have
We have 30 staff and its in a converted house-no real requirement for hot water just central heating
What should I pick and why ?
Also with a new condensing boiler what extra work do I need to factor in-do I need to cost for pipework to run to the outside of the building ??Are building regs involved?
Lastly what is the difference between Vaillant and W.Bosch
Intergas, less to go wrong, but the last thing you will ever get is unbiased advice with your question
system boiler is fine, combi if you want to have some hot water off it.
the new boiler will need a waste pipe connecting into your drainage system. The gas may need upgrading depending on choice. Building regs can be notified by your gas safe engineer.
valliant and WB are both good brands and make good boilers. stick to the boiler recommended by your engineer as its him/her who will be fitting and looking after it.
If you dont need it to produce hot water then a combi is probably pointless.
You can post your location and someone local might be able to give you a quote
Thanks all...you're fast !
I have had 2 quotes from local companies but both quoted on different systems and different makes of boiler so I was struggling to compare but your input has helped
When I say no hot water we will use some -hot water tap in toilets and a dishwasher ??on once a day.
My boss thinks that a combi would be better -"without a tank there is one less thing to go wrong "
Is that not true then
sounds like it would be a better choice to have a combi if you dont use alot of hot water and are currently heating a cylinders full.
Reply to the thread, titled "Advice needed choosing a new boiler for work ?" which is posted in Boiler Advice Forum on Electricians Forums.
