G
GenerationJones
Hi my Boiler is failing. It appears to run the central heating ok but the hot water runs intermittently hot then cold minute by minute. I have had the sensors changed but the advice points it to be the heat exchanger. Its old and I believe was a put in reconditioned. Latest plumber suggests the system is 'gunked' up and it needs replacing. He flushed some cleaner through the system to try and linp it on through xmas visitors etc but has now said he could replace it before xmas with a Baxi Platinum for 1900. I'd like it done BUT dont want to take a boiler that may cause me problems. I have a second quote coming in after xmas not on a Baxi.
Any thoughts on the original problem or the boiler offered? Thanks
